Discussion topic: Puk problems
This message was authored by: Scopie85
Puk problems
Why do I loose the picture when the program I'm watching reaches a break and I have to restart the puk to get it to work again. When I check on my sky for faults it says everything is working fine?
This message was authored by: Stephen+Mourton
Re: Puk problems
@Scopie85   Are you new to Sky Stream, or have you had it for a while and this problem has just started?  Does this happen on all channels?
If it is the former then there are a number of things to check.  Does your router have a direct line of sight to your puck?  Do you have a good internet speed? This can now be checked in 'Settings' then 'Network'.  When you restart the puck do you do it via the 'Settings' menu by going to 'Sysyem management' and 'Resets & updates'?  I hope that helps.
Avatar for Scopie85
Re: Puk problems
Had the puk for a good few months now and it does this on a daily!
When I restart the puk I do it via the settings tab.
The puk is wired direct into the router and to the TV with the relevant cables.
Quite often the voice sync is out and needs adjusting in the settings. But the thing that bothers me most is watching a program/film on any channel and as soon as an ad break starts the screen either pixelates or goes green and then you have to restart the puk in the settings.
Not impressed so far!
