Discussion topic: Puck plug doesn’t fit behind tv
Message posted on 25 Mar 2024 05:09 PM
Plug socket on puck is 3" deep and doesn't fit behind my wall mounted TVs?
stream advertises no cables I had TVs wall mounted cabling sunk in walls, now stream arrived and plug won't fit behind wall bracket??
what do I do? Why is plug so big? Can it be changed for a normal flat plug??
surely any wall mounted tv will have this issue and we took advice before having work done just never expected this plug??
Message posted on 25 Mar 2024 05:31 PM
Re: Puck plug doesn’t fit behind tv
@Simo1 wrote:Plug socket on puck is 3" deep and doesn't fit behind my wall mounted TVs?
Sky Stream still needs to connect to your TV via an HDMI cable so I don't know where you read the 'no cables' thing.
Message posted on 25 Mar 2024 06:19 PM - last edited: 25 Mar 2024 06:20 PM
That is Sky Glass advertising not Stream: "The only TV with Sky Inside. So you can stream every channel, show and app over WiFi. No dish. No box. No fuss"
@Simo1 The plug is needed as it has a transformer inside to ensure the power supplied to stream box is the correct rating, sky are unable to to supply an alternative. Googling Sky stream plug would have shown you the type of plug supplied.
I guess you could look at using an extension lead behind the TV some how?
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Message posted on 25 Mar 2024 06:24 PM
@Simo1 placing any wifi connected behind a wall mounted TV is asking for problems as TVs contain a lot of metal that blocks the signal. Why not connect the puck away from the TV and use a HDMI cable to link to the TV?
Message posted on 14 Jul 2024 05:56 PM
Use one of those plugs with 2 connectors and plug your puck on the top connector so it sits vertically
Message posted on 31 Jul 2024 10:25 PM
An extension lead??
Message posted on 14 Nov 2024 02:47 PM
It's actually a terrible design by Sky I had to use a 1 outlet short extension lead so the plug would aim up and not directly behind TV, next problem is the fact it uses infa red instead of Bluetooth for the controller so needs to be line of site not sure what Sky designers were thinking all everyone wants are cables and boxes hidden not possible with this.
Message posted on 14 Nov 2024 02:51 PM - last edited: 14 Nov 2024 02:52 PM
@Kingy22 wrote:It's actually a terrible design by Sky I had to use a 1 outlet short extension lead so the plug would aim up and not directly behind TV, next problem is the fact it uses infa red instead of Bluetooth for the controller so needs to be line of site not sure what Sky designers were thinking all everyone wants are cables and boxes hidden not possible with this.
The remote does use Bluetooth and does not require line of sight.
Try re-pairing your remote by following the istructions on the second page of this troubleshooting guide:
https://www.sky.com/help/articles/remote-control-help-sky-glass
Message posted on 14 Nov 2024 03:00 PM
Really? Will give that a try thank you
Message posted on 14 Nov 2024 03:34 PM - last edited: 14 Nov 2024 03:35 PM
Stream remotes have both Bluetooth and IR, but the IR is for basic control of non-Sky television sets and audio equipment.
Voice Control cannot function over IR: it requires Bluetooth bandwidth.
Message posted on 14 Nov 2024 03:45 PM
So does that mean it will not work on a non sky TV,(bluetooth remote)?
Message posted on 14 Nov 2024 05:19 PM
If there's a remote code, a Stream remote should control volume on a non-Sky television.
Message posted on 14 Nov 2024 05:28 PM
Excellent thank you very much
Message posted on 20 Jun 2025 04:44 PM
I have also just encountered this issue and called Sky to ask about a different plug. None are available so I had to cancel my Sky stream service. Such a shame 😞
Message posted on 20 Jun 2025 10:30 PM
If the cables you had sunk into the wall are in trunking then the best option is to put the puck at floor level and route an HDMI lead up to the wall mounted TV.
If that's not possible, another solution that comes to mind that might work, is to replace the mains socket behind the TV with one that also has a USB A socket in it, and use an USB A to DC Barrel connector cable to power the puck. ** This option will invalidate your Sky Puck warranty **
e.g.
https://www.amazon.co.uk/dp/B0CJBHC9D3/?th=1
and
https://www.amazon.co.uk/MyVolts-power-compatible-replacement-Stream/dp/B0CCY6GVBJ/
(It's up to you to research and decide if this option and the parts suggested are suitable for your purposes)
