Discussion topic: Puck in cupboard not receiving remote
Message posted on 05 Sep 2026 09:54 AM
Message posted on 05 Sep 2026 09:58 AM
Re: Puck in cupboard not receiving remote
@Cass50 I use a Harmony Hub & Remote (no longer available) these have IR blasters that can send a signal to devices out of sight, it sounds like the signal from the remote is no longer getting to the puck. May be worth investigating such a setup if you must have devices out of view.
Message posted on 05 Sep 2026 09:23 PM - last edited: 05 Sep 2026 09:24 PM
If you've created a barrier to Bluetooth reception then that's inevitably going to be a problem.
Try pairing your your Sky Stream remote again:
Press and hold 7 and 9 together for three seconds, then press and hold 1 and 3 together for three seconds until a connected message appears on your screen
