11 Nov 2023 08:34 PM
Trying to set up second puck and having issues at the pin number screen.
Got to "checking status" and after a few mins goes to "we coudnt connect to your account. Gave me an option to skp and set up later, but then says will not be able to watch anything. So, hit the go back otin and it is then asking me for my pin.
However, when i enter the 4 numbers (I have checked my pin, so I know what it is) it goes back to the start, and still says "Attempt 0 of 3" which seems weird. After going round in circles for an hour (and switching on and off several times) I have given up and hopefully someone on here can help.
12 Nov 2023 09:26 AM
Posted by a Sky employeeHi there, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
14 Nov 2023 09:54 AM
Posted by a Sky employeeWe are still looking to help you @DarrylG . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
14 Nov 2023 12:46 PM
Posted by a Superuser, not a Sky employee. Find out moreStream pin is normally the last 4 digits of the mobile number sky have on record for you
22 Nov 2023 06:13 PM
It won't let me inter my pin
22 Nov 2023 07:04 PM
Posted by a Superuser, not a Sky employee. Find out more@Gavin20 have you tried rebooting the device but putting it into standby mode, turning it off at the plug, waiting at least 30 seconds, turning it back on and then trying to enter your pin.
the pin will be the last 4 digits of the phone number associated with your Sky account.
25 Nov 2023 03:58 PM
Having the same issue and been calling sky all afterrnoon. no further forward. 2nd puck says incorrect pin. worked perfectly fine on the 1st puck. we have an account for 2 but wont let me set up 2nd. i have spent over 4 hours on this. Resets and everything else tried. un plugging, factory reset. sky taking forever tyo contact. Absolute nightmare . sky proving useless
28 May 2024 10:04 PM
Hi @DarrylG or @Kilczynski did either of you manage to get this resolved, if so, how? I'm struggling with the same issue and had a replacement puck delivered which hasn't helped
24 Jun 2024 04:44 PM
One of our picks stopped responding. Eventually gave up and reset it. Now It won't accept my pin. I have tried changing it with the same result with the new pin. Need help please.
03 Jul 2024 06:21 PM
I am having the same issue. Have had to reset my puck as said it needed a software update then white light kept flashing and wouldn't turn on. After reset I'm going through the set up again and when asked for my pin it keeps saying attempt 0 of 3. Tried resetting pin and that was successful (twice) but still says it's incorrect and I know it isn't. Now can't get past it. Help!
03 Jul 2024 06:24 PM
A different thread helped me after a number of issues, but you will need to speak to Sky as it's an account issue: https://helpforum.sky.com/t5/Sky-Stream/Sky-Stream-Puck-stuck-on-PIN-reset/td-p/4648407
04 Jul 2024 01:47 PM
Hi I'm having the same issues right now I know I'm putting in the correct pin but it keeps saying attempt 0 after typing it in so many times, I don't know what to do or how to resolve this.
04 Jul 2024 01:53 PM
@Chloe127 It's an account issue, you will need to speak to Sky
21 Sep 2024 02:27 PM
How did you get this resolved as we are having exactly the same issue now? Thanks
21 Sep 2024 02:52 PM
I had the same problem yesterday. I then changed my PIN, it asks for the last 4 digits of your bank account to do this. It accepted the new PIN but then asked me to enter it again and it reverted to the same problem.
I then restarted the puck after disconnecting it from the mains power.
After it restarted it asked for my PIN again, it wouldn't accept the new PIN but it did accept the old PIN and normal service resumed!
