5
This discussion topic has been answered Discussion topic: Puck Remote won’t switch off TV
This message was authored by: IanStarr
I've seen a few of these issues but no real resolution.
Puck needed a reset, set it all up but it won't switch off the TV. Switches it on, Switches Puck on, adjusts volume.
Was working all fine until this week.
Has anyone sussed it out ? Tried the remote reset numerous times, same result.
Avatar for IanStarr
Level 2 icon
This message was authored by: IanStarr Answer
Re: Puck Remote won’t switch off TV
Sorry but I eventually got it working. Think I went through nearly 20 of the 20+ Models it automatically found. Previously it had always been the first one.
@IanStarr
As you've mentioned a puck a couple of times I take it you have Stream so I'll move your post from the Sky Q board.
This message was authored by: Jporch316
Hi
presuming you are long pressing the standby button on your remote ?
Avatar for IanStarr
Level 2 icon
Yeh, I've rebooted a number of times. Reset the handset. It's just found the right TV before with no issues.  When I manually try to find the TV it doesn't recognise anything which I find strange. When I allow it to find the TV it has 24 possible options so I guess I'll just need to work through those until I find the one that does everything.
Doesn't take too long to go through them
Avatar for IanStarr
Level 2 icon
Answered - Go to Answer
