Discussion topic: Problems with sky stream
Message posted on 17 Feb 2025 05:42 PM
Message posted on 17 Feb 2025 05:45 PM
Re: Problems with sky stream
@Robertkeit Thats most likely a wifi or speed issue at your end. On the puck ipen netflix, go to get help and run connection test, what speed is being reported?
Message posted on 17 Feb 2025 05:46 PM
@Robertkeit that is a common issue which in the vast majority of cases due to the Puck not getting sufficent data. You can check the actual bandidth the puck can access by running the Network test in the Get Help menu in the Netflix app. Dont make the mistake of assuming the a decent connection to your router means wifi spedds at the puck must be great as the reality can be very different.
