Discussion topic: Problems with Apple tv plus
Message posted on 15 Jan 2024 11:24 AM
Hi, have just got AppleTV+ with SKY on the 6 months free trial but when I go to view anything on APPLE TV the TV screen goes Red and I I get is silhouettes of what's playing on the screen. This only affects APPLE TV .all other Apps are working fine.Have reset puck change settings but nothing works. Thanks
Message posted on 16 Jan 2024 12:34 PM
Re: Problems with Apple tv plus
What sort of HDMI cable is used to attach the Puck to the TV?
What model of TV do you have?
Have you completed a App refresh... which may take 24hrs to complete?
Message posted on 16 Jan 2024 02:34 PM
HDMI GOLD CABLE, have done refresh of Apple APP, apart from Apple tv all other APPs work .
Message posted on 16 Jan 2024 03:00 PM
@Huggy1950 wrote:HDMI GOLD CABLE, have done refresh of Apple APP, apart from Apple tv all other APPs work .
HDMI GOLD means nothing. The speed and spec of HDMI cables is important, especially when it needs to transfer UHD HDR streams to your TV. Ideally you should just use the cable that came with your Stream puck as it's a perfectly adequate high speed cable for such purpose.
Apple TV+ tends to use quite high bit rate encoding, coupled with Dolby Vision and Atmos, so the higher spec cable you use the better. You don't need to spend much - you can get excellent quality certified HDMI 2.1 cables from Amazon for less than a tenner. They need to be less than 3metres long too, any longer and you'll be in the realm of expensive optical HDMI cabling.
