4
This discussion topic has been answered Discussion topic: Premiersports on Sky Stream?
This message was authored by: Krankor
Hi 🙂
Does anyone know if you can subscribe to Premiersports with Sky Stream?
The Premiersports faq qoutes about Sky Glass, but no mention of Sky Stream?
Is Premier Sports available on Sky Glass?
Currently Premier Sports is not available on Sky Glass as it is a closed platform, only carrying Sky channels or channels Sky sell directly. Sky Glass does not support Airplay so you are unable to cast our Player to it either. We would recommend you subscribe to Premier Player until Sky begins to accept third party channels on Sky Glass.
When I seach for premiersports on Sky website it's not obvious if this is something I can add.
Is Premiersports player or Amazon the only real options available?
Appreciate any feedback on this.
Many thanks!
This message was authored by: MarkGoldsmith Answer
Re: Premiersports on Sky Stream?
That's correct currently premier sports isn't available via the Sky streaming platform.
Whether it's available at any point in the future will be a result of any discussions between Premier Sports and Sky. The process  typically drag on a bit as even if agreements are reached, legal work is always required to allow for cloud recordings and generally there is technical work required to integrate the billing process of both parties.
Avatar for Krankor
Thanks for the explaination, really appreciated!
This message was authored by: Paul+Boland
Note
If you based in Republic of Ireland
Premier Sports is available to watch on Sky Stream/Sky Glass and you can add to playlist for cloud recordings.
Republic of Ireland Only
Sports Extra Subscription = (TNT Sports + Premier Sports)
https://premiersportsireland.com/how-to-watch/
This message was authored by: Nick+Elliman
Subscribe via Amazon then you can watch it on the Amazon app.
