Discussion topic: Picture keeps freezing or goes blank
This message was authored by: Gordy60
Sky steam puck.
Avatar for Gordy60
Re: Picture keeps freezing or goes blank
Just joined Sky over a week ago. Brand new cable from outside pole and new box into house. Told to giive if a week to settle. Picture still freezing or going off. Any ideas and is this a common problem with.puck streaming?
This message was authored by: Dazzasky
Sky Stream doesn't connect from a cable on an outside pole @Gordy60 are you sure you have Sky Stream?
Avatar for Gordy60
Yes, it's a puck. An engineer ran a thinner cable ( he said it was copper inside) from the telegraph pole to a box on the outside of the house
This message was authored by: Hunter2660
OK. Run a speedtest via Stream's Netflix app, (not via your PC), and see the actual speed your puck is receiving.
Avatar for Gordy60
Ok, I'll try that
Avatar for Gordy60
Its 140. I've tried connecting an ethernet cable to se
@Gordy60 wrote:
Sky steam puck.
e if that works but it's just the same.
That should be more than enough. What speed are you receiving via your router?
Avatar for Gordy60
Not sure. I did a  system check and everything was okay.
Avatar for Gordy60
146. The ethernet cable would sort our the speed
An ethernet cable is always preferred as you can get interference from your neighbours wi-fi, as well as electrical sources. The puck is very sensitive to any drop in speed or online interference, as there is little buffering with the puck, unlike Fire TV, Roku sticks etc.
Avatar for Gordy60
Even though I've fitted the cable, the picture still freeze or stops. Is there something else that I need to do. I just plugged it into the box?
You will need to disable the WiFi in the puck's network settings and then reboot the puck.
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
Avatar for Gordy60
Ok. I'll try that tomorrow.  Thanks.
