Discussion topic: Sky stream puck not working
This message was authored by: Plumms
Message posted on 01 Aug 2025 11:19 AM
I've just had a new router. My pick is trying to update software but can't. It just sticks.
how do I get to settings to connect it to my new sky router.
This message was authored by: Jporch316
Find out more
Message posted on 01 Aug 2025 11:27 AM
Re: Sky stream puck not working
@Plumms wrote:I've just had a new router. My pick is trying to update software but can't. It just sticks.
In the first instance try connecting your puck to the new router via an Ethernet cable to get the update done
once you can get to the main screen use the reset network option in the settings to reconnect to your new WiFi network
