Discussion topic: Picture Intermittently Pixelating - Many Sky Branded Channels
Message posted on â14 Sep 2024 07:31 PM
Re: Picture Intermittently Pixelating - Many Channels
Bit worrying there's still no fix yet.
Message posted on â15 Sep 2024 02:11 PM - last edited: â15 Sep 2024 02:11 PM
@KevNewMedia 1408, Merlin, Sky Max HD. Can replicate by rewinding to show pixelation again.
Message posted on â15 Sep 2024 02:38 PM
It's awful again on UHD Sky sports main event
Message posted on â15 Sep 2024 02:43 PM
Really really bad. Seems to be getting worse.
Message posted on â15 Sep 2024 02:46 PM - last edited: â15 Sep 2024 02:55 PM
Sky greats hd . Gorillas in the mist. 1438 ish, 1450, 1452
Message posted on â15 Sep 2024 03:14 PM
Just emailed again. Makes no difference whether through WiFi or Ethernet
Message posted on â15 Sep 2024 05:47 PM
Managed to get two images of each issue today while watching F1 UHD.
First is where a frame from seconds before appears on a portion of the screen: https://i.imgur.com/bFvZUAY.jpeg
Second is where there's lots of greyish pixelation for a few seconds: https://i.imgur.com/wdGp3oP.jpeg
As I've said previously, these issues always appear on the bottom portion of the screen. And finally, I think the previous frame issue categorically rules out local environment issues, as no amount of WiFi lag or downstream issues can make a previous frame appear...
Message posted on â16 Sep 2024 12:34 AM
hi. same .sky have now sent 3rd puck and pixelation worse ,all bb checks etc ok . firestick apple devices all perfect. its defo sky puck hardware. i wont accept poor equipment any longer and need help to cancel my long left contract. am looking into ofcom
Message posted on â16 Sep 2024 11:32 AM
i don't think that definitely proves it's the pucks. Ok, all three of them might be crap. On the other hand they could all be ok. The problem may be on the other side of the router, upstream of your ISP, as others have said. (ie transmission problem.)
Message posted on â16 Sep 2024 12:15 PM - last edited: â16 Sep 2024 12:18 PM
Ofcom isn't appropriate. Your claim would be to Sky under normal consumer rights, that you believe the product isn't as described, of adequate quality and/or fit for purpose.
Message posted on â16 Sep 2024 06:22 PM
@madmitch66 You arent locked in to a long contract - you are free to leave as is everyone else. Sky will not hold you to your contract. No need to contact OFCOM. I would recommend that all the people moaning in this thread, contact sky - cancel and find an alternative provider or go back to Q. If you think your issues will be resolved anytime soon, you are going to be very dissapointed.
Message posted on â16 Sep 2024 06:53 PM
Been back with Sky Q for over a week now . And not had 1 issue regarding pixelated pictures. So it was obviously a platform issue.
I do hope they fix it soon though as it's annoying as hell
Sky Q 4K HDR Box
Sky Multiscreen
Sky Signature with Netflix. HBO Max and Disney +
Sky Sports Complete Pack
Sky Cinema
Sky HD and UHD Pack
TNT Sports
Virgin Media Gig1 Broadband
Sky Mobile Iphone 18 Pro Max 256GB Burgundy. Unlimited SIM
Message posted on â16 Sep 2024 08:30 PM
@Anonymous You are super helpful mate . I didn't know that đđ¤ˇđ forever greatful
Message posted on â16 Sep 2024 08:48 PM
@Anonymous We aren't mates mate. ok.
Message posted on â16 Sep 2024 09:40 PM
Incidentally on my Sky Glass I also have a Virgin stream box and when I watch TNT Sports Ultimate on that the sound is out of sync, the ads between go back to normal..
So I'm also on 350 meg Virgin Broadband and note that HDR content should be vibrant and vivid. It's not , it's grey and washed out.
As for sound quality there's no LFE channel for the bass or subwoofer (if there is one) the whole thing has been convenient and about needs a new incarnation of the Glass TV because the concept is brilliant.
