Discussion topic: Pair stream remote with alba tv
This message was authored by: HA05GER
Hi all
I have a older alba 19"TV in my garage that I'm using with a spare puck. I can't get the remote to tune for the volume on the TV or on and off. I've gone through the sky settings and selected alba but no luck. Is there a manual way to enter TV codes like you could with older sky boxes or is there another way I can try.
Tia
Re: Pair stream remote with alba tv
Have you tried other codes listed under Alba, not just the first one?
It can sometimes take going through about twenty or so of the available listed codes for one to work.
Avatar for HA05GER
Level 2 icon
The puck just gives me 5 to try then says it's not compatible
You could try the codes for Bush and Vestel, as they have been under the same brand of TVs in the past.
Avatar for HA05GER
Level 2 icon
Yeh I'll give it a go thanks. I just wondered if there was a way of manually entering codes like the old sky boxes.
No there is not any way to enter codes manually.
