7
This discussion topic has been answered Discussion topic: Pair Sky Stream Remote with a Monitor
This message was authored by: DaveMorr
If I connect my Sky Stream Puck to a monitor (rather than an TV) can I use the Sky Stream Remote?  If yes, how do I pair it?
Avatar for DaveMorr
This message was authored by: DaveMorr Answer
Re: Pair Sky Stream Remote with a Monitor
Thanks all. I will get a replacement TV
Who is the manufacturer of the monitor and which model is it?
Avatar for DaveMorr
I haven't bought it yet.  I wanted to make sure it would work with Sky Stream before I did.  Otherwise I will bu a new TV.  (It is currently connected to a TV.)
@DaveMorr  Most monitorsdon't have audio outputs on them so unless you have some way of hearing the audio such as an av amp it would be pointless, a proper TV would be best.
Choose your monitor then ask whether a puck and remote can be connected😉
@DaveMorr
Most dedicated monitors won't have remote control functionality.
Cheaper units which are essentially televisions anyway may do so.
This message was authored by: Skull+Treaty
I have an Amazon Fire TV Stick connected to an LG monitor: it has great audio but the screen aspect is a nightmare to get correct when switching from a laptop to the Amazon Fire TV Stick.
Avatar for DaveMorr
