This discussion topic has been answered Discussion topic: No sound on sky atlantic
Message posted on 03 May 2024 01:49 PM
I am trying to watch a programme on sky Atlantic and there is no sound. Sound fine on other channels
Message posted on 03 May 2024 04:35 PM
@MC69 After reading your post I have just checked Sky Atlantic on my Stream puck and it worked exactly as expected with perfect sound. This would indicate that the issue is at your end so I would suggest rebooting your Puck in case it has a minor software glitch.
TO do this just unplug it for a minute and then plug it in again. It will take about a minute to reboot.
Good luck 🤞
Good luck 🤞
