1
This discussion topic has been answered Discussion topic: No sound on sky atlantic
This message was authored by: MC69
I am trying to watch a programme on sky Atlantic and there is no sound.  Sound fine on other channels
This message was authored by: Fothergill1 Answer
Re: No sound on sky atlantic
@MC69  After reading your post I have just checked Sky Atlantic on my Stream puck and it worked exactly as expected with perfect sound.  This would indicate that the issue is at your end so I would suggest rebooting your Puck in case it has a minor software glitch.
TO do this just unplug it for a minute and then plug it in again.  It will take about a minute to reboot.
Good luck 🤞
Good luck 🤞
Answered - Go to Answer
