18
Discussion topic: No signal
This message was authored by Levicindy This message was authored by: Levicindy
No signal
We can only download on sky+hd box can't get any Tv
error msg no signal
we have followed online advice from sky gone to Settings and signal
input 1 and 2 signal strength and signal quality both empty boxes showing nothing
input 1 and input 2 showing not locked
any advice please
This message was authored by Annie+UK This message was authored by: Annie+UK Answer
Re: No signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Annie  ( Please Note: I am Neurodivergent )
Hardware: Sky+HD Services: Sky Go Extra (via Xbox Series X) • Box sets • Sky Cinema • Sky Sport Complete • Sky Multiscreen • HD Basic
Re: No signal
@Levicindy  "No signal" is normally a TV message, do you mean No satellite signal?  If so it may be your dish out of alignment, if thats the case you'll need to seek out  3rd party installer as Sky no longer maintain Sky+ setups, alternatively you could upgrade to Sky Q.
Re: No signal
This message was authored by Bristow23 This message was authored by: Bristow23
Re: No signal
Tried all the things mentioned.
This message was authored by Mark39 This message was authored by: Mark39
Re: No signal
You'll need to arrange an engineer, in that case, as @Annie+UK posted.
Re: No signal
How do I do that ?
Re: No signal
@Bristow23 wrote:
How do I do that ?
If you don't have Sky Protect, you'll need to find (and pay for) a local satellite installer to come out and have a look.
Alternatively, now might be a good opportunity to upgrade to Sky Q - the dish and cabling will be inspected at no additional cost as part of the Sky Q installation.
Re: No signal
@Bristow23 wrote:
How do I do that ?
Please Note: Sky+ is now a legacy service that Sky are winding down
Find a satellite company in your local area
This message was authored by MT531 This message was authored by: MT531
Re: screen says no signal
I can't access Sky for TV or apps screen showing no signal
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Re: No signal
Sorry,I don't understand what you mean, do you mean HDMI 1  ? If so it disconnected to that and the SKY logo shows on the screen, the light on the small box flashes for a short while then it goes off. Sorry if you don't understand what I've said. If that's not what you meant , I don't understand.
Re: No signal
@MT531 does the message on screen say 'no signal' or 'no satellite signal'? They're not the same.
Re: No signal
It says no signal. When I switch to HDMI1 the  Sky logo appears on the screen then disappears light on the box flashes for a while, then goes off and no signal is back on the screen. Sorry to sound thick but as you can tell I'm not at all "technically" minded
Re: No signal
@MT531 this doesn't sound like Sky+. Do you by any chance have a Sky Stream Puck?
Re: No signal
I think it is Sky Dtream
