Discussion topic: New sky puck no sound
This message was authored by: DUCADUCADUC
Hi,
just setup sky stream and I have no sound! Normal tv sound is as it should be, just nothing with the puck sound wise.
picture quality is good- possibly I gave up too early when doing the device setup. Can the puck be reset to factory settings?
This message was authored by: CoffeeDrinker
Re: New sky puck no sound
@DUCADUCADUC It could be that your TV/sound system doesn't like the default Dolby Digital Plus sound format the puck uses.
Try going to Settings at the bottom of the Home Screen > Picture & sound > Sound
Try setting the output format to Dolby Digital (not Dolby Digital Plus) and see if the sound starts working with that. If not, try changing the output format to PCM Stereo.
If you're still not getting sound at this point, it could be a fault with the puck itself. Try the above first and let us know the result.
Lounge: Sky Glass gen 2 65” volcanic grey, Denon X3500H AVR. M&K K Series 5.1.2 speakers, PS5 Pro, Apple TV 4K, Sony X800 M2 4K player.
Bedroom: Sky Glass gen 1 43” dusky pink, Apple TV 4K.
