50
This discussion topic has been answered Discussion topic: My5 won't load
This message was authored by: Kowster
My5 won't load
Like millions of other people on here My5 won't load, doesn't matter what you do. Please refer me to get some assistance with this. I have just about given up on Sky and it will be highly doubtful that  I renew my contract.
This message was authored by: KevNewMedia Answer
Re: My5 won't load
Posted by a Sky employee
Hi Everyone
Thank you for your patience. Whilst we continue to investigate this issue, as @Davidwm1 has mentioned, we've managed to resolve the problem with the steps below.
Please note, by carrying out these steps, the following will happen:
  • All apps, except Netflix, will be signed out (you can sign back in afterwards).
  • Your remote control will unpair (you can repair with the on-screen instructions).
  • Your playlist will re-populate as soon as you've gone through the reset.
If you are happy to go through the steps, you can carry out a factory reset by using the steps below:
Settings > System Management > Resets & updates > Factory reset
I'm going to mark this post as the answer, so that everyone see's the most recent update.
Kev
Community Manager
Re: My5 won't load
@Kowster
On what device do it not loading on ?
Avatar for Kowster
Re: My5 won't load
Sky Stream puk.
restarted, refreshed
This message was authored by: Bill051
Re: My5 won't load
Fine on Stream for me today. Not used it before so had to register. No problems.
It's odd that Stream problems usually affect only some users and not others.
exSky Broadband, exSky Stream via ethernet
Amazon Firestick
Previously VM
back to VM
Avatar for Kowster
Re: My5 won't load
There's never any assistance or any concern,  trying to contact Sky is like trying to have dinner with the Scarlet Pimpernel.
It's a joke. £62 a month for a useless substandard service. Shame on you Sky.
Believe the hype!!
This message was authored by: Treeman33
Re: My5 won't load
Mines not working either, I can't find a way to report it
Re: My5 won't load
@Treeman33
I use the My5 app on Stream daily and not had any problems with it recently.
Are you getting any errors, or can up you describe how far it gets when launching.
Assume you have tried a Sky Puck restart and an app refresh;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
App refresh:
  1. Press Home on your Sky remote, then select Settings
  2. Press System management then Resets and updates and finally Refresh apps.
  3. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing. The refresh can take 24 hours to complete.
Re: My5 won't load
Hey,
Yea I've tried everything twice for the past 3 days! The milkshake advert screen comes up as soon as I open the app, then I press OK and a wheel just spins. I give up after 5 minutes
This message was authored by: Steve93
Re: My5 won't load
I've just loaded My5 on my puck, Milkshake appeared, clicked on ok, My5 opened no problem
surely though when you add a ch5 program to you Playlist it plays through the cloud, you don't have to use My5, pretty sure that's how ot works
This message was authored by: Barney81
Re: My5 won't load
My Sky Stream is doing exactly the same thing and has been for the past 3 days.
Re: My5 won't load
@Treeman33
I've escalated this to Sky and they should be in touch with you soon about it.
Look out for a message from Sky on your email and Sky Community private messages.
Look out for the blue chat bubble within your Sky community.
More about an escalation here;
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Re: My5 won't load
Can you try what I have laid out in Post 7 above, this normally resolves this type of issue.
This message was authored by: Addie15
Re: My5 won't load
Hi there! Thank you for escalating this. We have sent an invite to Treeman33.
Avatar for Kowster
Re: My5 won't load
Exactly what is happening to mine! Never an easy way to contact Sky, I'm so tired of it. Never again!!!!
Re: My5 won't load
I tried this on the first day I noticed the issue and again yesterday, I'm still getting the same issue. I also installed the My5 app on my phone and it opened as you would expect. The issue is definitely with the My5 app on the device, my guess would be that something is blocking the connection between the device and the My5 application server.
