Discussion topic: My sky stream tv is not working
This message was authored by: TRACK1
We have just come back from a holiday and the sky stream TV is not working
This message was authored by: A+JW
Re: My sky stream tv is not working
Could you provide any more information? Is there an on-screen message?
An ex-Sky Stream customer
Do you mean a Sky Glass TV or a Sky Stream Puck attached to a TV?
This message was authored by: Phxntomation
Hi @TRACK1 ,
Would you be able to provide more context about the issue?
Do you see any error messages? Does the device not turn on etc?
Sky Stream Customer + Sky Cinema + Sky Mobile
Not a Sky employee
@TRACK1 I'm not sure if you have a Glass TV or a Stream puck attached to a normal TV but either way the first thing to try is a reboot.  Simply switch off your Glass or Stream puck at the plug socket and wait for a minute before switching it on again.  It will take about a minute to reboot.
If that doesn't help them post back with more information as suggested by @Phxntomation and @A+JW
This message was authored by: Sky1934
I had the same problem. Problem solved when I changed the batteries in the remote control !
