Discussion topic: My remote won’t work the my tv
This message was authored by: Jom18
Message posted on 20 May 2026 07:52 PM
My remote won't work the sound on the tv
Find out more
Message posted on 20 May 2026 09:33 PM
Re: My remote won’t work the my tv
Hi @Jom18
You haven't given the community to go off, such as the make and model of the TV. Try resetting your remote and setting it back up again as per the instructions here: https://www.sky.com/help/articles/your-sky-glass-remote
Under "Use your sky remote to control your TV". It may be a case that you need to try multiple settings / "codes" before you find one. But the onscreen instructions should guide you though.
MikeAlanR
