Discussion topic: My TV hub light is flashing
Message posted on 24 Oct 2026 07:16 AM
Message posted on 24 Oct 2026 08:48 AM
Re: My TV hub light is flashing
@Mprice1234 So are you sayimg your broadband is down? If so who provides your broadband service?
Also if your broadband is down so will Sky Glass/Stream as they rely on an active broadband service to operate.
Message posted on 24 Oct 2026 10:00 AM
@Mprice1234 wrote:
I can't get onto my TV as my sky hub for the TV isn't working the light is flashing and just won't connect to the TV to watch anything
Do you mean your Sky stream puck that is connected to your TV?
If so, that sounds like it your Sky Stream puck is stuck in a standby state.
Can you try performing the recovery procedure on step 4 of this Sky help article;
Message posted on 24 Oct 2026 11:39 AM - last edited: 24 Oct 2026 11:50 AM
@Mprice1234 I had exactly this issue last week with the latest updates , on both of my pucks , its a corrupted update , you need to force the puck to redownload a full puck OS , if you look at my own post down below you will see how to do it it fixed the issue on both pucks 1st time no amount of restarting , factory resets or pulling the plug fixed it as its essentially a bricked device due to OS corruption.
Also when you do the procedure if you can have a wired connection to the puck as sometimes doing this on wifi can produce a stuck at "0" downloading screen
https://helpforum.sky.com/t5/Sky-Stream/Software-Firmware-boot-loop-Fix/m-p/5396604#M85119
2x Sky Stream Pucks | 2x Hisense 55" UHD | 1x Sony 42" HD
Sky Ultimate + Cinema + Whole Home | Max/Netflix/P+/Disney+
(Just a customer helping customers. I do not work for Sky.)
