Discussion topic: My Sky TV won't start up
Message posted on 02 Jul 2025 09:17 AM
My 4 lights are all green but when I press the power button on the Sky remote the smaller box just flashes a white light, and nothing loads up on the TV.
Message posted on 02 Jul 2025 01:28 PM
Re: My Sky TV won't start up
I'm guessing you mean all 4 lights on your broadband Hub, and the smaller box is your Sky Stream Puck.
I'll move your post to the Stream forum. It's definitely not a Sky+ issue.
First thing to try is to turn your Puck off at the plug for 30 seconds or so, then see if it will start up ok.
Message posted on 02 Jul 2025 02:03 PM
@Steve503 wrote:My 4 lights are all green but when I press the power button on the Sky remote the smaller box just flashes a white light, and nothing loads up on the TV.
You have connected the small Sky Stream puck to your TV via HDMI cable and selected the appropriate HDMI input on your TV haven't you?
