Discussion topic: My Sky Stream review
Message posted on 12 Feb 2024 12:39 PM - last edited: 12 Feb 2024 12:50 PM
Installed straight out of the box without any issues.
Picture quality on high definition is outstanding and much better than sky q.
HD and UHD pq in my opinion is almost the same. Colours are vibrant and clear. Sound quality is excellent.
I do miss the page up , page down for quickly scrolling through the live stream channels.
The programmes on the epg that are also available in uhd aren't clearly labelled You get the "watch from start " without the "also available in UHD" and does not trigger my tv's hlg/hdr on screen graphic which would otherwise be the only notification that a programme is UHD.
In summary this is a fantastic box of tricks with outstanding picture quality and outshines Sky Q. A big thumbs up from me 😁👍
I will add to this as time from time to time if necessary
Message posted on 12 Feb 2024 01:52 PM
Re: My Sky Stream review
@cookiemonsteruk Pretty much my experience and thoughts. I moved from Glass to stream in early December and find Stream much better than Glass.
Page up and down can be achieved on the EPG by a slightly longer press (& release) of the up/down on the circular button. It's not as good as the dedicated Sky Q button but is still effective.
Message posted on 12 Feb 2024 01:57 PM
What is apparent is that its too easy to bring up BBC i player without clicking on it.
Message posted on 12 Feb 2024 05:55 PM
@cookiemonsteruk wrote:What is apparent is that its too easy to bring up BBC i player without clicking on it.
Think this happens when you click on the bbc1 tile just above the tv guide ... very easy to do and very very annoying
Message posted on 12 Feb 2024 07:52 PM
I would value your thoughts on this for someone whose wife likes the ability to record and how that compares with SkyQ please. Maybe we just miss the Betamax video recorder.
one other ask if I am very cheeky please @cookiemonsteruk. I have seen you fairly busy on other threads 😉 can I connect a Netgear Orbi direct to the ONT with Sky Ultrafast and if so what are the credentials? Apologies for the cheeky ask
Message posted on 12 Feb 2024 09:32 PM
I have enquired via our community managers re: how much we can divulge in respect to recordings. Hopefully i'll get back to you one way or another tomorrow
Please post in the broadband forum and tag me . Many thanks
Message posted on 13 Feb 2024 09:00 AM
Grateful and looking forward to the Stream update. I am moving into a new house. Have always used SkyQ and have an order in for the same again. If the experience on record was good stream would suit much better so I will wait out with interest
Message posted on 13 Feb 2024 09:49 AM
Ok, as it stands a lot of content is held on various apps etc so adding to a playlist simply invokes the app to play.
For programmes tha have no on demand presence ie live sports pressing the red add to playlist actually invokes a cloud recording. The firmware is been rolled as we speak but i haven't tried it yet. Hope this helps
Message posted on 13 Feb 2024 10:40 AM
Thanks for taking the time. I might dial back on that Sky Q order and try this
Message posted on 13 Feb 2024 02:32 PM
Agree with the opening poster. Sky customer for over two decades and I was on Sky Q pretty much from the start. But I find Stream to be better, barring a couple of technical hitches like the puck not coming out of standby with Bluetooth on my newer hardware.
The only other real thing I miss is the stability that rewind and fast forward on local storage gives you. The stream version works, but is a bit ropey and inconsistent. But it's inevitable as it's time shifting a stream. I'm sure there will be improvements with it as we move forward.
Message posted on 13 Feb 2024 02:41 PM
@Kempston wrote:Agree with the opening poster. Sky customer for over two decades and I was on Sky Q pretty much from the start. But I find Stream to be better, barring a couple of technical hitches like the puck not coming out of standby with Bluetooth on my newer hardware.
You will find that the voice control fast forward or rewind X minutes, is an improvement on having to use the buttons on the remote in some situations.
Message posted on 13 Feb 2024 03:49 PM
I'll need to read up on voice commands. Whilst available on sky q i never really used any. I guess sky stream is a paradigm shift for a remote control traditionalist like me
Message posted on 13 Feb 2024 04:08 PM
Sometimes i just try things by luck and see if they work with the voice commands 😀
Message posted on 15 Feb 2024 08:43 PM
Well, I have had Sky Stream for just under a week, and I must say I am impressed. I came from Virgin Media, and Sky Stream feels so much more modern. Picture and sound quality excellent
Message posted on 17 Feb 2024 04:51 PM
Thanks all. I got a fairly decent deal this morning and swapped out the Sky Q order for three Sky pucks with full package and Ultrafast plus.
