This discussion topic has been answered Discussion topic: Moving home - Sky stream
Message posted on 21 Nov 2024 02:48 PM
Message posted on 21 Nov 2024 03:27 PM
Yes, you still need to contact Sky, to update the address they hold for you.
Message posted on 21 Nov 2024 06:44 PM
Re: Moving home - Sky stream
Technically you are only allowed to use sky stream in the household that is registered with sky. There is an IP check possible which in the worst case scenario can block your access to sky.
as @Mark39 states you need to notify sky of your new address and moving date
