16 May 2023 07:59 PM
Hi all,
Looking for a bit of help.
I have my stream plugged into a 2022 Sony OLED and Sonos Beam. Both DolbyVision/Atmos have been working fantastically.
Wierdly, last night, any programmes that should be in Vision are now just showing as 4K HDR in Netflix/Disney Etc. Atmos is still working fine but I can't get Vision.
I've tried power cycles, updating apps, switching HDMI but nothing seems to be working to bring back Dolby Vision? I hadn't changed any settings and when I access content through the TV's inbuilt apps it shows in Dolby as it should?
Any ideas?
18 May 2023 02:42 PM
Hi @Tim+Adams and @Greenfingers001
Problem now sorted. Software update had been installed on my Sony TV and my HDMI settings had been changed. When I checked after the problem occurred it was showing on 'Enhanced' but turns out if I'd bothered to look properly I'd have seen a new 'Enhaced Dolby Vision' option in the HDMI settings.
Sky engineer was a great help. Thanks again for the referral.
16 May 2023 08:11 PM - last edited: 16 May 2023 08:13 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @thecrag79
If you switch it all off at the socket, then plug the Stream direct to the TV and then turn Stream & TV on does Dolby Vision work?
Thanks,
Tim
16 May 2023 08:21 PM
17 May 2023 07:47 AM
I'm going to escalate this to Sky who will then invite you to a chat to troubleshoot with you.
The link below explains how escalation works, please look out for the invite.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Thanks,
Tim
17 May 2023 05:40 PM
Posted by a Sky employeeThanks for escalating this. We’ve sent an invite to chat.
