Discussion topic: Lip Sync issues - Sky Stream
Message posted on 15 Jan 2025 05:31 PM
Re: Picture not syncing with speech on programs
The lip sync issue has been going on for nearly a year
Message posted on 15 Jan 2025 07:21 PM
I filled out the form also. Had to dig out the date I joined Sky as they asked when the problem started for me and it was as soon as I started trying to stream TV on Sky Stream.
Message posted on 15 Jan 2025 07:24 PM
The sound is ahead for me generally. As in you hear them speak and then their lips move to speak the sentence after I've already heard the sentence.
Message posted on 15 Jan 2025 08:40 PM
So basically it's not currently fit for purpose?
Message posted on 15 Jan 2025 08:46 PM
Reposting this from further back in the discussion to see if it helps anyone in the iterim while Sky work on the situation. It still continues to work for me when I get a lip sync issue...
@P11RAR wrote:After some tinkering around with incredibly out of sync BBC channels, I have found a temporary work around to re-sync the audio track.
With the off-sync channel on, on your Stream remote there is a button with three white dots under the power button. Press this. You'll see a menu on the lower third of the screen with subtitle and audio options. Change the audio track to "English AD" - this will cause the feed to re-sync. If an AD (audio description) track accompanies the picture, you'll hear that, but if it doesn't it will automatically revert to the standard English audio track. If it does have an AD track after you switch it over then you can just switch it back to English and the audio track will remain in sync.
Although not ideal this work-around has continually worked for me.
Also, my audio settings are set to pass-thru.
Message posted on 16 Jan 2025 02:20 PM
We now have an Apple TV 4k+ up and running and it's wonderful in comparison! No issues at all, it all just works sooooo nicely we and can use Now TV for the odd thing on Sky 🙂
We will cancel our subscription at this point and I don't have anything further to add to this discussion. I will see if I can unsubscribe.
Good luck all 👍😅
Message posted on 16 Jan 2025 08:18 PM
Re: Problems with sky stream
hi i'm having the same ! sound not linking with commentary 😞 what did u do ? steve
Message posted on 16 Jan 2025 09:06 PM
Have moved your post to this ongoing thread discussing your issue.
See the Sky response within this thread;
https://helpforum.sky.com/t5/Sky-Stream/Lip-Sync-issues-Sky-Stream/m-p/4866033#M42352
Please submit the form, as requested in that post
Message posted on 16 Jan 2025 10:17 PM
Lip sync issues
Did all you asked, now worse than ever.
Goes out at the start of every ad break
Message posted on 17 Jan 2025 01:02 AM
Re: Sky tv sound - constantly out of sync
Hi
I have the same problem, and I know it is a puck issue as when I watched the same programme through sky broadband (delayed) on ITVx via Smart TV, and also via Sky (the puck) - no problem with the former but trouble via the puck. Sky support have admitted sync issues over the phone which they hope to rectify soon, but all they did was give me a new puck, which still has the same problems.
I have to admit also having problems with broadband speeds - on Superfast I am promised 55Mb/sec minimum download speed, and at best get 35Mb, but can go do down to 4-12Mb sometimes.
Basically Sky - you need to come clean.
Your puck is not fit for purpose, whether the issue is hardware, software issue or both, I am not certain, but you have delivered a product not fit for purpose without testing in advance (or worse, ignoring your results!).
In the meantime, I find switching to audio passthrough in settings helps the most when audio is inevitably behind (and pausing and/or fast forwarding to live helps too).
PS: In the interests of balance I was previously a customer with Virgin Media, and had audio sync issues there too - though nowhere near as bad as with Sky. As an original punk band once said 'No One Is Innocent'!
Message posted on 17 Jan 2025 06:43 AM
Please submit the form, as requested in that post.
Message posted on 17 Jan 2025 08:59 AM
Re: Sound and vision
This has been going on for nearly a year with nothing coming from Sky about fixing it
Message posted on 17 Jan 2025 09:02 AM
@Chloe-W22 All this is the contact who is from Sky and responded once Ref. Lip Sync Issues never to be heard from again @Chloe-W22 ......... She did send a form out🤣
Message posted on 17 Jan 2025 09:23 AM
@Chloe-W22 did reply a week or so after the initial post and said they are close to a solution, given the severity of the issue and the number of users impacted you would have expected a solution by now, and regular updates, but this doesn't seem to be the case.
Message posted on 17 Jan 2025 10:37 AM
Just an additional datapoint here :
Watching Kindig Customs on Discovery this morning, I am hearing a lot of Audio drop out, without seeing any video issues, the drop out seems to accumulate and after a few minutes the sync has drifted by quite a large amount - never seem it this bad TBH.
Changing channels resyncs as we know
FWIW
