1595
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: Jonathanphillip
Re: Audio sync issues with sky puck
Taking advice from  other members on here it seems to have worked  changing it to pcm seems much better than before many thanks 😊 👍
Re: Lip sync problems with puck
Sky forum will remove any unnecessary comments if they feel like its nasty language or comments or any inappropriate comments which goes against there tc swearing or bad language or other hate comments
This message was authored by: Hilbur1
Re: QS025 Lip Sync Issues
We have this issue as well. So many issues woth sky but mostly their broadband.
@Hilbur1 Have you followed the advice already given multiple times in this thread?  Sky have suggested that if you are experiencing the lip sync issue you should change your audio settings to PCM or passthrough as a temporary measure whilst they find a more permanent solution.  I actually have mine set to Dolby Digital + and don't have any lip sync problems.
This message was authored by: Zer0reZ
Cheers, this workaround has brought the lipsync back in spec albeit somewhat tinny as a result, it's a little concerning the supplied puck system is not performing as contracted, it would be helpfull for a timeframe to fix the issue with dolby?
This message was authored by: ALCOPSE
Problem with sound not syncing with lips.
I have a stream puck and have followed all the help but there is no difference. I turned it off a number of times to see if it reset and rectify the issue, I have tried other channels without any luck. I there anyone who had the same issue and how was it fixed.
This message was authored by: MND1
I have same issue, are you saying SS is no longer compatible with sound bars? Because it's out of sync on tv speakers.
This message was authored by: JerseyLife
Sky Stream Sound/Picture out of sync
Been working fine for 2 years but last few days, intermittent sound/picture being out of sync. Happens on all channels. Happens on average once and hour. Do I need a new puck ?
Re: Sky Stream Sound/Picture out of sync
@JerseyLife  Sky are aware of this lip sync issue and have been working towards a solution.  There is a large thread on the subject HERE
So you don't need to wade through the thread Sky have suggested that while they find a permanent solution a temporary workaround is to change your audio settings to PCM or Passthrough.  Personally I have mine n Dolby Digital + and don't see the issue.
gold channel out of sync
still gold out of sync the rest off channels ok after changing to pcm many thanks
This message was authored by: kittencatkatie
I've just switched back to Sky Stream after two years of BT TV this morning, and coming back in and turning the tv on just now, have encountered this problem.
I've read everything from page 6 of this forum onwards, so I'm well informed, and have done the PCM workaround, which appeared to be immediately successful. As someone else has remarked, though, the sound appears a little more tinny, and 'luckily' I am not one of those people running the audio through an external speaker/system.
Either way, it seems insane for this to have been a (very impactful) known issue for at least 3 weeks, and 2 after being acknowledged by an employee and a test fix trialled with very mixed success, and still have the effect clear on a brand new, immediately fully-updated, puck.
Can we be sure the workaround will continue to be effective, and will be notified if the issue is sorted, as it certainly should be?
It's really not a good welcome back to the Sky TV ecosystem after two years in the wilderness. One of the reasons I was fully convinced to make the leap back was the ludicrous scenario experienced over the past couple of months with BT TV in which, over internet mode, any time subtitles were turned either on or off, the picture and audio would freeze entirely and jump for a second!
@kittencatkatie Welcome back 😀.  I don't disagree with you at all so let's hope there is a fix in the next update. Personally I have my puck set on the Dolby Digital + audio option and the only drawback I have found is I need the volume up a touch higher but at least there is no lip sync.
The trial fix that Sky ran with some volunteers (as mentioned earlier in the thread) had mixed results which is presumably why it was not rolled out to everyone.  I guess patience is the name of the game for us all.
This message was authored by: Eve16
Sound on tv not in snyc
Sound is not in sync watching sky tv
This message was authored by: Nigelb1972
Re: Sound on tv not in snyc
Try changing the Audio output from the settings menu to Passthrough
This message was authored by: Arthur2236
Why does Sky Stream appear to be out of sync specifically on BBC Channels
We are new to Sky Stream and are relatively happy with the service. However, we are finding that the streaming sync between audio and video is lost especially on the BBC Channels and even more so during daytime viewing. Our broadband provider (EE) has advised that they have no issues. Could you advise why the loss of synchronisation is happening
Locked
Answered - Go to Answer
