Discussion topic: Lip Sync issues - Sky Stream
Message posted on 10 Apr 2025 12:35 PM
I've noticed a change in volume at the start of a program. I didn't pay much attention but it looks like you are right
Re: Sky puck lip sync issue
Same versions of everything here - but had another call this morning saying sync is out...wondered if I'd left the 100ms delay on I'd tried to resolve the issue with...but no, I'd set it back to 0ms and she's right, there is still definitely a noticeable delay. Movement on the screen comes before the sound arrives.
Will try tinkering with the Sonos settings, but I'm thinking the latest Sky software update hasn't fixed this as intended 😕
Message posted on 10 Apr 2025 12:47 PM
All the latest versions I believe - same issue present.
changing channel seems to give SOME improvement - but it's still not synced up at any time.
Message posted on 10 Apr 2025 02:20 PM
@MattCray yes that's the latest at the moment. What's your setup? Do you use a soundbar or a built in speaker etc? Is this on any particular channels?
Message posted on 10 Apr 2025 02:26 PM
Thanks.
yes - using a sound bar - a Sonos Ray connected optically.
Puck connected into the Samsung 4k Tv via the HDMI that came in the box with the puck.
Seems to be on all channels to be honest - and gets progressively worse.
Message posted on 10 Apr 2025 02:43 PM
Thanks @MattCray
When It comes to lip sync issues they're often dumped together as a single bug but there's probably a bunch at play and it sounds the most recent update didn't fix it for the one you're experiencing unfortunately.
One quick question, is it possible to run it with eARC via HDMI rather than optical to see if that behaves any different? That might be useful data for Sky to look into next.
Message posted on 10 Apr 2025 05:40 PM
@Anonymous wrote:Thanks @MattCray
Believe the Sonos Ray has no hdmi connection at all. Purely connects from the optical audio out on back of TV's.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.058.00P; UI 4.10.4; Platform Version 8.4p58s1 | Sky Broadband Superfast
Message posted on 10 Apr 2025 05:48 PM
Ah so you're right!
Message posted on 10 Apr 2025 05:50 PM - last edited: 10 Apr 2025 05:53 PM
@MattCray wrote:Thanks.
What audio setting do you have the puck set to? The Sonos Ray only supports either PCM Stereo or Dolby Digital. I'd have Sky Stream puck set to Dolby Digital with a Sonos Ray. Also with it coming from the TV's optical audio out you should also check your actual TV audio settings themselves too as they sometimes have audio sync settings for the optical out on the TV.
Message posted on 10 Apr 2025 06:03 PM
@kendoe47 I completely agree and been saying this for a while. The puck I don't think and many others have said the same thing, including Sky engineers and they say it needs major improvement
Message posted on 10 Apr 2025 07:38 PM
Hi All, Just watching the darts on Sky, lypsync is back. You hear the thud of the dart before it hits the board most annoying. Tried the Skygo app on my Samsung tablet no sound issues at all. I am convinced the puck is at fault. Major problem in my view. Sky cannot sit on this, it needs addressing pronto.
Message posted on 10 Apr 2025 07:41 PM - last edited: 10 Apr 2025 07:42 PM
Completely agree @kendoe47 it's stuttering on channel 922 so much during the golf. Not good enough Sky
Message posted on 10 Apr 2025 08:56 PM
You have indeed. And yet the Puck works fine for most which would suggests no major hardware improvement is needed.
Message posted on 10 Apr 2025 08:57 PM - last edited: 10 Apr 2025 09:02 PM
Don't agree and if you look at many messages there are several others who have issues
One of these days all issues will be fixed. Have to say the lip sync is better now but got black screen again on the latency channel and also stuttering.
Message posted on 10 Apr 2025 09:14 PM
Don't agree....
I know. But on what logical basis?
