Discussion topic: Lip Sync issues - Sky Stream
Message posted on 29 May 2024 12:30 PM
Re: QS025 Lip Sync Issues
@Paul+Dray wrote:BTW my pucks updated today from QS027.508.00P to QS028.516.00P
Yup, the rollout has indeed started, will likley take a few weeks before all customers are on it.
For those customers who had the lip sync issues, when you are upgraded its worth testing to see if the issue has been solved in the new update.
Message posted on 29 May 2024 12:31 PM
Re: Sky puck lip sync issue
Unfortunately many soundbars will only have the one hdmi port, so putting it between the puck and TV isn't an option in such cases.
Message posted on 29 May 2024 12:37 PM
@CPoin wrote:Unfortunately many soundbars will only have the one hdmi port, so putting it between the puck and TV isn't an option in such cases.
They should have at least one hdmi input and one out to tv hdmi port. Admitted not much. My fathers soundbar is like this so I've added an hdmi switch into the loop with that connected to the one single hdmi in. The other thing that can work with lip sync issues is to feed the audio from the tv digital out to digital in on the soundbar.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.052.00P; UI 3.291.1; Platform Version 8.4p52s1 | Sky Broadband Superfast
Message posted on 29 May 2024 12:39 PM
Er..yep I'm pretty sure that's the first thing those having issues will be doing. 😉
Message posted on 29 May 2024 12:42 PM - last edited: 29 May 2024 12:43 PM
@Super+Anthony wrote:Mine hasn't as yet.
Much different? @Paul+Dray
I've not really checked the various sound modes as I'm always on pass thru to my AV receiver anyway so I haven't been affected by the issues. Really need someone who has to then report back when upgraded.
Message posted on 29 May 2024 12:43 PM
Using a Sonos Beam that has only one HDMI. Have had to use optical connection instead which still uses the single port. No way to send a signal in and out again. Means no Atmos but solved the lip sync issue for now, and Atmos on the Beam is totally unnoticeable anyway.
Message posted on 29 May 2024 12:47 PM - last edited: 29 May 2024 12:48 PM
@CPoin wrote:Using a Sonos Beam that has only one HDMI. Have had to use optical connection instead which still uses the single port. No way to send a signal in and out again. Means no Atmos but solved the lip sync issue for now, and Atmos on the Beam is totally unnoticeable anyway.
I'm not really familiar with the sonos soundbars. Seems crazy to only have the tv hdmi port with audio return 😕
Message posted on 29 May 2024 12:50 PM
Is it worth in doing taking out the plug and doing the restart or just be patient
Message posted on 29 May 2024 12:53 PM - last edited: 29 May 2024 12:54 PM
@Super+Anthony wrote:Is it worth in doing taking out the plug and doing the restart or just be patient
Cant hurt. Though I did this yesterday and no change, but for it to then just update over night on its own. I always check the version in settings every time I use the puck. When I see it's had an update I then immediately turn off and unplug for 30s then back on just out of habit.
Message posted on 29 May 2024 12:59 PM
Thanks @Paul+Dray
Message posted on 29 May 2024 01:08 PM
When you put the plug back in, I notice that the Sky logo comes on. Once it has done this nothing happens, so I press the Home Screen on. It then does the normal please wait
Is this correct? Or do I not press the Home Screen
Message posted on 29 May 2024 01:12 PM
You cannot force an update.
As mentioned above, early morning the following started rolling out to Sky Stream and Glass customers.
It will be rolled out slowly as usual to customers and will take a few weeks to reach all customers;
1.3
QS028.516.00P
Not aware if the lip sync issue fix was part of this release.
Will ask in our Superusers closed forum area.
Message posted on 29 May 2024 01:21 PM
Thank you @lettice
It does though on the Sky site say you can, so this is slightly confusing, particularly if one is neurodivergent, but thank you as always
Message posted on 29 May 2024 01:28 PM
@Super+Anthony wrote:Thank you @lettice
That will be allowing you to do an update of the firmware, if your current software is stuck ( sometimes happens on initial setup) or you have for some reason not updated correctly.
Until your pucks have been sent over an outgoing rolling release (like we have with QS28 and 1.3) you will not be able to force that one.
