595
Discussion topic: Lip Sync issues - Sky Stream
This message was authored by ken+mackenzie This message was authored by: ken+mackenzie
Re: QS025 Lip Sync Issues
No
one is so is playbar connected optically from tv
other is lgsky10 connected via arc from tv
Both did work fine
Now the one connected to lgsky10 has the sync issu
This message was authored by Paul+Dray This message was authored by: Paul+Dray
@ken+mackenzie wrote:
No
Both did work fine
Good info and doesn't surprise me that the one connected via optical from tv is ok.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS033.014.00P | Sky Broadband Ultrafast
This message was authored by Binkie79 This message was authored by: Binkie79
Lip sync issues with sky pucks
We yave had our sky stream pucks for around 4wks now & they were great at first but for the last 2wks we have had  major issues with lip sync. Its way off no matter what setting we change it to.
any advice much appreciated
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Lip sync issues with sky pucks
@Binkie79welcome to the forum.  There was an update about a week ago which has caused the latest lip sync issue.  This is a long thread to read through so to save you the trouble the current advice is to change your audio settings to PCM or Passthrough.  This is a temporary workaround whilst Sky fix the issue.  Strangely the issue does not effect everyone.
If my post has solved your issue please mark as an "Answer"
Thank you..... I will try this
This message was authored by McQueen10 This message was authored by: McQueen10
I have sky stream and over the last week my sound has gone out of sync
I have sky stream and over the last week the sound has just gone out of sync I have tried everything I could to fix the problem but it's still out of sync
This message was authored by Peter682 This message was authored by: Peter682
Re: I have sky stream and over the last week my sound has gone out of sync
I changed the audio setting on the puck from auto to PCM stereo..been working fine for the last week...no software update as yet..
@McQueen10There was an update about a week ago which has caused the latest lip sync issue.  The temporary workaround suggested by Sky is to change your audio settings to PCM or Passthrough.
Sky are working hard to find a solution 😀
This message was authored by Charlotte007 This message was authored by: Charlotte007
Recurring voice delays on tv
Sound is delayed on all channels . Have turned off box twice . Works for so long then happens again
This message was authored by FunkyL This message was authored by: FunkyL
Despite turning to passthrough, has started to happen again tonight.  Switching channels made it go away, for a bit... also got lots of glitching/corruption on the screen, and some form of dynamic resolution thing going on.  We seem to be watching most programmes in 720 or something despite it supposed to be at UHD.  Is there an option to cancel our contract early as this is not what we signed up for - surely some form of trades description thing applies?
Re: Recurring voice delays on tv
@Charlotte007 Have you tried the temporary workaround that was suggested by Sky and mentioned though out the thread?  The recommendation is to change your audio to PCM or Passthrough, which seems to work for most but not all people but is certainly worth trying. Personally I have mine set on DD+ with no lip sync.
This message was authored by Ashleyburton This message was authored by: Ashleyburton
Re: Sky puck lip sync issue
Same for me. Only happened over the last week. Ridiculous that this can't be sorted after so many reports of this.
I tried syncing Tv delay and Sky delay but nothing works.
Netflix via the TV app works fine, the same as Prime, it only happens with Sky.
Please update as it's driving me nuts!!
This message was authored by nmbailey This message was authored by: nmbailey
As mentioned on other threads, it is a Stream issue caused by the last update. The workaround is to change the Sound Setting from Auto to Passthrough
This message was authored by Emilyastleyxxx This message was authored by: Emilyastleyxxx
Lip sync miles out on all channels
On sky stream, the lip sync is miles out on all channels, have to restart puck then it's okay for abit, then will start again. Any suggestions why or how to sort??
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Re: Lip sync miles out on all channels
@Emilyastleyxxx
Changing the audio output on the puck to pass-through instead of auto is said to help for some customers. Or try PCM but you won't get Atmos or 5.1 with that.
Sky are supposedly working on a fix but no date has been given for it.
