1607
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: Trev55
Re: SKY STREAM - New software build QS021.005.00P caused new audio sync issue
Same issue for me been fine for six months now it is all over the place, it is doing my head in. Lip sync issue started 5/4/24 as far as I know
This message was authored by: Hoppy+55
Thanks Michael, just read your post, & changed mine šŸ‘
Dh
This message was authored by: AnthonyPev1960
Do Sky Customer Services actually read these threads?
This message was authored by: Pukkajim
I have called and explained the issue to retentions and they've allowed me to cancel immediately.
in all honesty the lady was amazing and it's instantly gone off and I'm now back to Apple TV 4K. (With no lip sync issues)
Avatar for GD1
Level 16 icon
Re: Sky puck lip sync issue
All
This has been raised to Sky but unlikely we'll get any updates before Monday 8th April.
In the meantime have you tried different setting in the pucks sound settings menu?
*****Post marked as Answer for visibility only******
Sky do read these threads, so should be aware
They also have been made aware in our Superusers closed area, so hopefully for those having the issue may get some traction soon.
As  I have mentioned elsewhere on this community, I have tried a number of tests with TVs, sound kit combinations and puck settings tweaks last few days and am not seeing this problem with my Sky Stream pucks, so it seems to be a certain combination of kit,  not solely the puck itself.
This message was authored by: Paul+Dray
@Mr221 wrote:
@Paul+Dray
we have had the same problem since the new update two nights ago sky stream can you sort it out never a problem before
Not sure why I've been linked to this post. Maybe was just to get my attention to it as I was the one who started the earlier software update audio problem thread.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck: Sky OS 1.3; Build QS040.058.00P; UI 3.301.2; Platform Version 8.4p58s1 | Sky Broadband Superfast
Re: QS025 Lip Sync Issues
My settings have been left on Passthrough which was what fixed the issue for me a while back on earlier software versions. It still seems to be ok although I did think it possibly looked a tiny bit out after the last update. Nothing like some people are experiencing. Though I haven't tried the other audio settings since settling on passthrough to my AV amp.
BTW it would be helpful if everyone would say which version they have currently on their puck. Mine for example updated a few days ago to QS025.017.00P.
This message was authored by: Floydianslip
I'm watching the Brighton v Arsenal game on Sports Main event, audio is Atmos, this isn't just lip sync problems, the sound is 10-12 seconds behind!! I've never had sync problems, the SO25 firmware needs rolled back to SO24, how could Sky get it this wrong!?
This message was authored by: Mark2024
Re: Lip sync problems with puck
Lip syncing has suddenly become unwatchable.
surely sky will allow us to cancel our contracts if they can't deliver a basic part of the service agreement?
@Mark2024 You would have to call Sky to discuss cancelling your contract.  If you are outside of the 31 days cooling off period you might be able to argue your case that the service is unfit for purpose.
With regards to the lip sync issue you could try different sound settings.  I have mine on Dolby Digital + and have not had any problems with the lip sync so that might be worth a try.
Good luck šŸ¤ž
This message was authored by: Tommy1959
Re: Sound keeps going out of sync
This has been happening every 20 -30 minutes on my sky puck. We have 2 and it's happening on both. 2 different tv's so it's not the tv that's at fault. Tried everything suggested by sky's automated diagnosis chat. 🤬
Originally posted in the Sky+ forum.
I called up today and was instantly able to cancel and I was month 2 into a 28 month contract.
18* month contract
Locked
Answered - Go to Answer
