Discussion topic: LG Remote Code Not Working Correctly
This message was authored by Craignabaa This message was authored by: Craignabaa
Something has changed with the LG TV Remote codes it seems?
The Sky puck was setup a few weeks ago and has worked fine. Today the TV, an LG 128TN515S which was not previously listed as a supported model, but worked on option 4(?) when working through the codes, stopped working completely.
I replaced the batteries, and did the reset 1-3 / 7-9 which got the menu going, but not the TV power/volume.
When pressing the Volume up to test the remote settings in [Setup Remote to control the TV] the Sky TV Search item comes up in the bottom corner instead.
I went through the Remote setup again, both selecting the specific TV model, and going through all 15 LG options, but no joy Everytiime we get the Search bar instead of Volume up.
With the actual model now appearing on the list of supported models, it seems possible that the update/change has in fact broken something?
Has anyone else experienced similar?
This message was authored by TVGuy91 This message was authored by: TVGuy91
Re: LG Remote Code Not Working Correctly
Yeah, my Stream remote suddenly stopped being able to control either my LGC2 or my LG Eclair Soundbar as well. Trying all the LG Codes for either made no difference, none of them got any response. It had been working consistently since October 2022 prior to that.
This message was authored by Viks This message was authored by: Viks
Go to settings > connected devices > click on remote > control a speaker system > write LG, rhen it will ask you of volime workes try using the volume button that should work.
