Discussion topic: It's saying my sky stream restricted
This message was authored by: Marialesley
Ans ive not even been with u a day
Re: It's saying my sky stream restricted
This sometimes means a payment has failed. Does it say anything in your MySky app?
Also, try giving it a reboot and see if it persists.
@Marialesley  That's not a good starrt to your Sky experience.  As this is a user forum you are not addressing Sky by posting here.  You will need to call them to get help in resolving the issue
I can't post the phone number for you as the forum blocks them for security reasons but follow this link https://www.sky.com/help/home and scroll down to need more help at the bottom of the page, click on this and you will see an 0333 phone number to use to call Sky.
This message was authored by: M...Carter
I often get this message when I first switch on. I just press the Home button and it goes away and everything then works as usual. Just one of many "features" of the wonderful Sky Stream.
