20
This discussion topic has been answered Discussion topic: Issues With ad skipping
This message was authored by: Tommy2
I have added on ad skipping to my Sky account and was advised that thsi would work with channel 4 and ITV,  Unfortunetly it is not removing the ads from Channel 4 nor letting me skip adverts. I have started a trial for Channel 4 + and that works letting me skip the adverts howver, my underatnding is that this was included in Sky by deafult and taht I wouldnt ahve to pay extra to skip adverts on Channel 4 and ITV. Any help or advice would be mcuh appreciated.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
This message was authored by: Hunter2660 Answer
Re: Issues With ad skipping
I can see you have some annoying issues with Stream. If it's any help I have a Now subscription, the savings in making the switch allows me to sub to ITVX and Ch4 for ad free content. At the end of the day it's whatever works for you. If you can go without Sky's OS, and free Netflix etc. then maybe have a rethink and try somewhere else for Sky's content. Don't stick with something if it's really not working for you.
This message was authored by: Stephen+Mourton
Hi @Tommy2   I sympathise with you.  I have found on Sky channels the add skipping is very elegant and works well.  Likewise iPlayer which is BBC's system works very, however the ITV system is not as good and the Channel 4 and Channel 5 are very poor.
One thing I have found is if you wait for the adverts to actually start and then press the skip app it works better.  That being said watching Countdown on Channel 4 on catchup it was a nightmare.  I would stop it at the end of the adverts watch for a few minutes then it would cut out and return me to the adverts I thought I had just skipped.
Avatar for Tommy2
Level 5 icon
Thank you @Stephen+Mourton that is most helpful, I ahve been able to skip the ads on ITV shows by doing what you suggested, howevr on Channel 4 it only lets me skip them when I started a trial for Channel 4 + which has removed all ads, hwoevr there is clearly no point paying for Channel 4+ when Sky ad skipping is meant to work with Channel 4. Whilst I do really like Sky stream and being able to watch Sky TV all through the internet there are some things that could be improved. I certainly do miss being able to fast forawrd ads as I was able to on Sky +.
The ad skip works differently on each app. On the ch4 app, if I remember, you need click f/f and hold, then it starts working through the ads. Can't remember how the ch5 app behaved. You'll need to experiment with each app to find a solution that works for you.
Yeah exactly this, the method of skipping or fast forwarding the ads will vary app by app.
Sky Stream, Sky Glass Air and former Sky Broadband customer
Avatar for Tommy2
Level 5 icon
Thank you, I'm aware it works differently on each app @MarkGoldsmith  however, as mentioned on Channel 4 app it didn't work when Sky ad skipping was added, it only worked when I signed up to a trial of Channel 4 +, which as mentioned I shouldn't have to pay for seeing as Sky ad skipping is already meant to work with Channel 4 app.
What was happening when you tried to fast forward to the ads on the C4 app, was it just not responding to you press the FF button on the remote?
Did you try a reboot of the puck or an App Refresh to see if that resolved the issue?
A Channel4+ subscription removes all ads from on demand content so there is no need to attempt to fast forward with the Sky Stream remote.
It's worth pointing out that I subscribed to Channel 4+ for a couple of months then cancelled it. It then offered me 3 further months for just £1.99pm which I have taken. I abhor ads of any kind so am much happier paying for ad-free than the glitchy ad-skipping Sky offer.
Avatar for Tommy2
Level 5 icon
thank you @Angel_Aka  I am fully aware of that but I meant before I joined Channel 4 + as a trial it wouldnt let me skip ads.
@Tommy2
I think I'm understanding what you are saying.
I do not often use the C4 app, maybe a few times a week.
I have ad skipping and just given it a good test ( whilst moved to watching the test cricket on Sky Go), with some films,  a few new progs and some of my current playlist episodes I have.
Its running fine.
As above its a shame all these many apps in their approach for such things along with ff/rew timelines are slightly different, but it becomes second nature after some weeks/months or three years or so in my case of using Sky Stream.
With the C4 app, let the ad start, then click the outer right part of the select button and hold it down. Once it starts moving through the advert timeline, click once and/or twice on the middle part of the select button and let go after each of those clicks and it will move through the ad timeline faster.
As above what happens when you press and hold to f/f? Doesn't it eventually slide through the ads? If you expect it to skip in the same way as the Sky on demand stuff it simply won't. It isn't designed to do that.
Avatar for Tommy2
Level 5 icon
No it doesn't skip neither does ITV however as mentioned on channel 4 + it does. I think Sky do need to coordinate with channel 4 better to make this happen.
Ah! I think I see what you're getting at now. Unless you subscribe to the apps in question, then the ads will always be there. What the ad skip on Sky enables you to do is fast forward through the ads, similar to a PVR recording. This is something that can't be done using the ITV or Ch4 apps on any other device.
Avatar for Tommy2
Level 5 icon
@Hunter2660 yeah thats it but unfortuantely even that is not working all the time.
