3
This discussion topic has been answered Discussion topic: Issue with sound
This message was authored by: LynnH22
Issue with sound
Sound keeps dropping off, comes back on when I turn tv off and on again. Thought it was the tv so bought a new one, but still happening. Have reset the puck, again not helped. Any thoughts?
This message was authored by: Angel_Aka Answer
Re: Issue with sound
What are the audio output settings on your puck? Try setting it to PCM stereo if you're connecting it straight to the TV and don't have a soundbar.
Avatar for LynnH22
Thanks for getting back to me. The sound was on auto, I have changed it as you suggested, will see if that helps. Thanks again.
Fingers crossed!
Answered - Go to Answer
