2
Discussion topic: Issue with Sky stream set-up
This message was authored by Eamon2 This message was authored by: Eamon2
Sky stream arrived today. After connecting to my broadband it was sitting at "Sky stream setup" checking your status. Then it said software error. Third time trying now. Have unplugged and plugged back in.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith Answer
Re: Issue with Sky stream set-up
It's possible if it stays stuck a reset will fix it. This shouldn't cause any unforeseen issues as the puck isn't setup yet anyway.
1. Turn the puck off at the plug.
2. Turn over the puck and hold down the power/standby button.
3. keep hold of the power button and turn the plug back on.
4. Keeping holding the the power button down until it turns amber and then it should turn green. Then you can let go.
5. The puck is reset, you'll have to connect to Wi-Fi or whatever you use,  set up the remotes and then you'll get an activation code.
6. log into the sky activate site and enter the code and that's it.
Sky Stream and Sky Broadband customer
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Make sure you keep it off at the wall for a good couple of minutes then try again. It's also adviseable to connect via ethernet to get the software update done.
