Discussion topic: Is sky stream as good as sky stream
Message posted on 14 Apr 2025 09:20 PM
Hi, how much do u all recommend sky stream
Message posted on 14 Apr 2025 09:26 PM
Re: Is sky stream as good as sky stream
I have 2 sky glass tvs and a puck and they all work fine but i have also got sky gigafast broadband 900mps which help and i have them all connected by ethernet cables more stable than WiFi i also have a sky live camera to
Message posted on 14 Apr 2025 10:56 PM
@Anonymous I really like Sky Stream. The subject of this thread is a bit confusing though, can you clarify? Maybe you meant another Sky product?
Consider liking this post if it was helpful, or mark as an answer if it solved it for you.
Sky Stream customer. Past user of Sky Digital, Sky+, Sky+ HD and Sky Q. 3x pucks. Main TV is an LG OLED with Sonos Beam.
Message posted on 15 Apr 2025 07:50 AM
Personally, I love Stream but we have a solid 500mbps internet connection with the puck receiving a solid and stable WiFi signal. However, not everyone is getting on so well.
Message posted on 15 Apr 2025 10:23 AM
I've liked it so far mostly. Better to use than Q, I think it's a better picture too. Plus having 4k on extra pucks is great. Q was awful really, mini boxes always playing up even on Ethernet. Stream seems definitely better, but I have had a few issues. It's disconnected from WiFi a few times and frozen once.
Message posted on 15 Apr 2025 11:43 AM
Depends entirely on how you watch TV.
If you only use one TV and like having more control of your viewing, setting recordings, watching what you want, when you want, then Sky Q is the better option.
If you have fast & stable broadband and don't mind Sky and other broadcasters/streamers having more control of their content's availability, and would like UHD on multiple TV's (bandwidth permitting) then Stream is the better option.
Message posted on 15 Apr 2025 12:21 PM
The reason for not getting sky stream is that I live in a village and can't get full fibre broadband.
Message posted on 15 Apr 2025 12:25 PM
Also I don't get why they call sky Q award winning if they are phasing it out be 2029.
Message posted on 15 Apr 2025 12:43 PM - last edited: 15 Apr 2025 12:44 PM
@Anonymous wrote:Also I don't get why they call sky Q award winning if they are phasing it out be 2029.
It won awards so it's fair to say that. And it's worth noting that Sky hasn't publically said phasing it out by 2029, that's a bit of conjecture based on satellite end of life dates. In practice they've kind of phased it out already for most new customers because it's not really advertised on the Sky site anymore, you really have to dig for it.
Without good broadband Sky Stream isn't a great option, but the good news is that the country is really getting its act together with fast internet through fibre, satellites and 5G and by the time Sky Q does eventually shut you'll probably have no issue getting Stream!
Message posted on 19 Apr 2025 11:32 AM
Ah yes. If you've not got good internet I bet stream would struggle. Do a speed test while holding your phone where the stream box would be. I think they say min 25mbps for 4k and 35 if you have more than 1 box but based on what I'm reading in this forum I'd be wanting at least double that to be sure. What is your actual normal top speed? You could look at new router or Ethernet or something if it's fast enough next to router but not at the potential location of stream box.
Message posted on 19 Apr 2025 11:34 AM
When Q came out almost 10 years ago the specs were very good and some of the functionality was ground breaking. However it never worked great, mini boxes were awful in many cases, mine included. You can see how it won awards for the theoretical functionality though.
Message posted on 19 Apr 2025 11:40 AM
@Dallybally I think a stable connection appears to much more important than a fast one. I manage speeds of around 80mbps with Sky Broadband and my Stream works brilliantly 99% of the time. Yet with my 1gb Virgin connection which wasn't stable at all the Stream struggled.
Message posted on 19 Apr 2025 11:43 AM
My virgin 1gb seems fine, I only get half the speed as the cable is damaged and they can't get to it to repair. I have got an expensive asus mesh network though, maybe it was virgins router causing the problems?
Message posted on 19 Apr 2025 05:29 PM
Basically sky stream is an app that links all the other free and paid for apps together. Stream adds little itself, except maybe Sky Atlantic.its guide is poor. You get loads of adverts that you can't rid of. Fast forwarding and reversing is hit and miss depending on which stream service you're using. Sometimes you can see where you are, sometimes you can't. But you always get to see all the adverts over and over if you Ff or fr over an ad break. You even get adverts when paused.
I get pixelated videos occasionally, rebooting solves that. I'm on my 3rd remote control, can't control TV volume now (was OK). Sony Bravia TV. If I had a choice now, I'd go back to just using freeview.
Message posted on 20 Apr 2025 10:15 AM
I've a part fibre connection running at about 54Mbps (standard speedtest.net) and the Sky Puck (stream) works effortlessly even with simultaneous other video demands (e.g. BBC iPlayer) on my router. My Puck is connected to the router by Ethernet. you don't need a full fibre connection. Like you my area doesn't have full fibre available.
