This discussion topic has been answered Discussion topic: Intermittent searching for signal
Message posted on 13 Oct 2026 04:09 PM
My sky keeps going off saying no signal then turns on again. It is doing this repeatedly.
Message posted on 13 Oct 2026 05:16 PM
If the light on your stream puck is staying on then the message is from the TV.
Firstly check the HDMI cable is fully inserted in both the TV and puck.
Try a different HDMI input in the TV.
Try a different HDMI cable.
Check the puck video output is set to a value your TV can accept.
Message posted on 13 Oct 2026 10:39 PM
Re: Intermittent searching for signal
Thank you. I changed the HDMI port on the back of the tv and this seems to have worked, so far! Thank you so much .
