Discussion topic: Intermittent WiFi connection on sky puck
This message was authored by: MM2311
When the puck is first turned on it says there is no WiFi connection If it is rebooted by turning it off and on at the mains then it works but of course it takes some time to reset Very annoying
This message was authored by: SuperMatt
Re: Intermittent WiFi connection on sky puck
Posted by a Sky employee
Morning, @MM2311. I'll send you an invite to a private chat shortly and we can help you get this working for you.
Just look out for the colourful bubble to start the conversation. Please be aware conversations automatically close if there is no response within 48 hours. Here's more information on how Community Messaging works - https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M141
Hi @MM2311  Check that Networked Standby Mode is turned on in settings.  This stops your puck losing the network connection when it goes into standby.
To check go to Settings > Start up & Standby > Networked Standby Mode.
