Discussion topic: Initialise new sky stream puck activation code issue
Message posted on 03 Sep 2025 06:22 PM
Git all the way through set up of new sky stream puck but at linking to account activation code does not move me forward to full set up
tried 6 x with reset process but still no joy
Message posted on 03 Sep 2025 06:28 PM - last edited: 03 Sep 2025 06:30 PM
Re: Initialise new sky stream puck activation code issue
I've We've moved your post to the Stream board as it's not a Sky+ issue.
Message posted on 03 Sep 2025 08:34 PM
@Will17794 Are you signed into your MySky account at www.sky.com when you enter your activation code? If not it won't work and you will probably get an error message.
Message posted on 03 Sep 2025 09:17 PM
Hi
yes fully signed in and no error message at all.
can key in the activation code but then nothing happens.
we think it may be due to poor and fair internet connection despite just getting B4RN fibre installed today.
