Discussion topic: I’m trying to set up the system and I need a verification code. How do I get it please?
This message was authored by: NIJD
I have sky account
How do I activate the system? I don't have a verification code I have not been sent one and I can't find one in the box.
Re: I’m trying to set up the system and I need a verification code. How do I get it please?
@NIJD the activation code should appear on your TV screen during the setup process.
Once you have it log into your My Sky account at   https://www.sky.com/mysky
Once logged in go to https://www.sky.com/productsettings/streaming-tv/activate This is where you can enter your activation code that appeared on your screen during setup.
The following link is to a setup help guide if you encounter problems: https://www.sky.com/help/articles/setting-up-sky-glass-help
There are also some informative setup videos on YouTube.
Also, if you are asked for a PIN the default is the last 4 digits of the phone number you have registered with Sky (you can change it later).
Good luck.
This message was authored by: Michael1201
I have a activate code
OK. Anything we can help with?
Hi @Michael1201 and welcome to the forum.  I am guessing you have your Activation code and now don't know what to do with it.  If I am correct have a look at post 2 of this thread.
If this is not your issue and you need some assistance please give some more details so a forum member can try to help.
