Discussion topic: I can’t activate my sky stream
Message posted on 08 Feb 2025 04:27 PM
I tried to activate it but it won't
Message posted on 08 Feb 2025 04:33 PM
Re: I can’t activate my sky stream
Any error messages?
Message posted on 08 Feb 2025 05:34 PM
Hi @Abraham4 you haven't given much information to work with so I am giving a you a few general options.
Are you signed into your My Sky account at https://www.sky.com/mysky If not sign in before entering your activation code.
During setup you must also be using the same email that is registered to your account.
Once logged in go to https://www.sky.com/productsettings/streaming-tv/activate This is where you can enter your activation code that appeared on your screen during setup.
The following link is to a setup help guide:
https://www.sky.com/help/articles/setting-up-sky-glass-help
If all else fails call Sky for some additional troubleshooting.
