30 Apr 2024 10:37 PM
Hello. I just wondering how to buy sky box office events on sky stream?
30 Apr 2024 11:16 PM
Posted by a Superuser, not a Sky employee. Find out more@Farenden2024 No you can order on the Sky Puck using the remote 👍
If you look at the link I provided and select the option "Buying a Sky Box Office Event" and then select "Sky Glass or Sky Stream Remote" it gives the instruction to order through the puck. It actually says to do the following:
I would still follow the link as there is other useful information.
Good luck and enjoy your box office programme 😀
30 Apr 2024 10:47 PM
Posted by a Superuser, not a Sky employee. Find out more@Farenden2024 Welcome to the forum. I have never purchased a Box Office event myself but the following link should answer any question you have on the subject.
https://www.sky.com/help/articles/sky-box-office
30 Apr 2024 11:07 PM
Do I need to call sky and tell them I would like to order sky event on my sky stream puck?
30 Apr 2024 11:15 PM
