2
This discussion topic has been answered Discussion topic: How do i reset my sky pin
This message was authored by: GMan2025
I have forgotten my sky pin and been round and round the help passages. My sky tv doesn't give me an option to go to settings - or i can't find it. It's driving me mad. Please help
This message was authored by: lettice Answer
Re: How do i reset my sky pin
Your PIN is the last 4 digits of your mobile number you used when ordering.
If you have since changed it;
You can also update it through the Sky menu. On your Sky remote, select Home > scroll down and select My Sky > Manage your PIN > Forgot your PIN?.
You’ll need your bank details to hand, as you’ll be asked to enter the last 4 digits of your payment method to reset it. For Direct Debit payments, that’s the last 4 digits of your account number.
You'll see this error screen if you enter the wrong PIN 3 times. To reset your PIN, follow the steps above.
Blocked your PIN? For security reasons, if you enter the wrong PIN 3 times in a row, we’ll block it for 10 minutes. After the 10 minutes, try again. We won’t be able to unblock it any sooner.
More details here;
https://www.sky.com/help/articles/your-sky-glass-pin
More details here;
This message was authored by: Pauline391
I don'have a pin are some programmes subscription only?
Answered - Go to Answer
