This discussion topic has been answered Discussion topic: How do I set up sky stream
Message posted on 20 Feb 2026 02:05 PM
Got sky stream today and I've been trying to set it up. It's been stuck on the "checking your status" for over an hour
I've tried turning it off an on again, I've tried several other things I've found from other people who had this problem and nothing is working
Message posted on 20 Feb 2026 02:45 PM
Hi @Ashleigh64 I have put a link below to a troubleshooting guide when the puck get stuck on checking your status. Work through it and hopefully this will.
Good luck and post back if you are still having issues.
