Discussion topic: Home Move & Switching from Sky Stream to Sky Q
This message was authored by: Thevoid
Hi, I'm about to move home and have Sky Stream which is out of contract.
I want to move address and change from Stream to Q. Is there anyway to do this online?
If not, will Sky tell me to cancel Stream, wait for 31 days, then I can order Sky Q?
I've been unable to contact anyone at Sky about it and was hoping someone would know.
Re: Home Move & Switching from Sky Stream to Sky Q
hi @Thevoid
The only path for stream to Q is by calling Sky this cannot be done online. They will usually terminate stream and arrange Q but there may be a period without service. However not sure how much the house move will muddy the waters.
If you are a Sky broadband customer you can arrange that move online. See: https://www.sky.com/moving-home
But for Q you will need to call them on 150 from Sky landline or mobile or on the 033 number under need more help on this page: https://www.sky.com/help/home
MikeAlanR
This message was authored by: Jporch316
Might be best if you move house first , change your address etc with sky then after a short period switch back to a
