Discussion topic: Frame Mismatch
Message posted on 14 Oct 2026 07:04 PM
Frame Mismatch
I'd love to get customers' experiences with regards to frame mismatching on Sky Stream. I've tried every way possible to minimise it, but the juddering at times is driving me mad! If Sky doesn't introduce actual frame matching by the end of my contract, I'll be cancelling. It simply isn't good enough!
Message posted on 14 Oct 2026 09:06 PM
Re: Frame Mismatch
@Kiero84 never experienced anything that might be attributed to frame mismatch.
Message posted on 14 Oct 2026 09:22 PM
Re: Frame Mismatch
I guess you're referring to in-app playback?
Message posted on 14 Oct 2026 09:24 PM - last edited: 14 Oct 2026 09:25 PM
Re: Frame Mismatch
As in this thread: it's the 50Hz vs 24fps thing.
Message posted on 14 Oct 2026 09:29 PM
Re: Frame Mismatch
No, I'm noticing it directly on Sky channels as well. Under Salt Marsh is a real culprit I'm finding.
Message posted on 14 Oct 2026 09:36 PM
Re: Frame Mismatch
That's odd: anything made for a UK television channel should be in a native frame rate.
