Discussion topic: Frame Mismatch
This message was authored by: Kiero84
Frame Mismatch
I'd love to get customers' experiences with regards to frame mismatching on Sky Stream. I've tried every way possible to minimise it, but the juddering at times is driving me mad! If Sky doesn't introduce actual frame matching by the end of my contract, I'll be cancelling. It simply isn't good enough!
Re: Frame Mismatch
@Kiero84 never experienced anything that might be attributed to frame mismatch.
Re: Frame Mismatch
@Kiero84
I guess you're referring to in-app playback?
Re: Frame Mismatch
@Mark39
As in this thread: it's the 50Hz vs 24fps thing.
https://helpforum.sky.com/t5/Sky-Stream/Sky-absolutely-need-to-support-framerate-matching/m-p/536612...
Avatar for Kiero84
Re: Frame Mismatch
No, I'm noticing it directly on Sky channels as well. Under Salt Marsh is a real culprit I'm finding.
Re: Frame Mismatch
@Kiero84
That's odd: anything made for a UK television channel should be in a native frame rate.
