Discussion topic: Fibre
This message was authored by: Tl131
Fibre
I was upgraded to fibre yesterday. I am on sky stream (which I hate!) and since then, Internet drops outconstantly. Getting fed up with watching TV with 10 second gaps every minute!
Re: Fibre
@Tl131  How is your puck connected to the hub?   Having Fibre is only as good as the speed to the hub, beyond it will be variable depending on a number of factors.
If WiFi to the puck drops out frequently that would suggest poor signal from the hub
Avatar for Tl131
Re: Fibre
Sorry, no idea. The engineer did everything as the router had to be moved. The puck is about 6 ft from the router.
