25 Sep 2023 03:00 PM
Hi,
I ordered abd received two Sky Streaming pucks several months ago, however, one of the remotes hasn't worked since I received it. The one that works, lights up upon picking it up, unlike the second one that doesn't . Is there a fix or do I need a replacement?
25 Sep 2023 03:14 PM
@Immortaal1 wrote:Hi,
A glance round this forum will reveal that you are not alone. These remotes are pretty flaky - faulty ones seem to be being reported multiple times a day at the moment.
Follow the troubleshooting here:
https://www.sky.com/help/articles/remote-control-help-sky-glass
If that doesn't work, try giving it a firm twist with both hands (as if wringing out a towel) - this can sometimes tweak the contacts into a functional position. If it still doesn't work, ring Sky and ask for a replacement.
